Did search can't find out what to do with these
Swapping h22a4 into 94 del sol si, wiring is done, shifter is done, but where do I hook these up to? they are on the back of the trans.
Re: Did search can't find out what to do with these (Trooper)
VSS? Do I need to do anything else? Is there any fluid that goes through these lines, they were hooked into the steering rack on the prelude.
Re: Did search can't find out what to do with these (teknics1)
Those hook up to your power steering lines coming off of you rack, on your rear crossmember. If your car does not have power steering, just loop (close off) the hose so you close and seal the vacuum. If you have PS lines coming off of your rack, on your rear crossmember, connect the hoses to those lines.
'06-V6-MT
06-30-2015 05:47 PM
1993gsrcivic
02-08-2009 07:20 AM
