Need info on 00 ITR into 95 civic
Ok I'm doing this swap for a friend. I want to know what you have to change on the b18c5 to make it OBD1. Everything I've read said its a b1tch to swap the car to OBD2. So thats out of the question unless theres a easy way to do it. Also any tips would help.
TIA
TIA
Re: Need info on 00 ITR into 95 civic (GTibunny8v)
You can drop the complete motor in and retain all OBD2 components on the engine including the engine harness and simply use a chipped P28 or P30 OBD1 ECU.
Re: Need info on 00 ITR into 95 civic (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">You can drop the complete motor in and retain all OBD2 components on the engine including the engine harness and simply use a chipped P28 or P30 OBD1 ECU.</TD></TR></TABLE>
true dat.
thats what i did, except i had a 96 usdm gsr instead of a c5 and swapped into a 92 dx hatch. i bought a stock p28 and had it chipped and reprogrammed by ericks racing......
true dat.
lampshadej1
Engine Management and Tuning
06-10-2010 02:51 PM
