Hey idea for h22 shafts
Just out of curiousity couldn't you use the prelude intermediate axle and then use the 94-01 integra drive shafts instead of using the accord intermediate axle and the 90-93 integra shafts. Because essentially the only difference in the 2 sets of shafts is the 90-93 shafts are femal/female while the 94-01 shafts are male/female. Just something I was wondering on.....
Re: Hey idea for h22 shafts (jdmcivicferio)
The 94 teg axles are still a little too long. I've used the prelude intermediate shaft and an 88 teg axle with a prelude inner joint. It worked OK but I still think the accord intermediate shaft and 90 teg axle works better.
Re: Hey idea for h22 shafts (hybrid_KJ)
I'm still surprised nobody really does it or trys it, they always just seem to get a 90-93 accord intermediate axle and 90-93 integra shafts, but I guess since it works why change it....
but has anyone else tried that setup of 94-01 integra shafts and prelude intermediate axle?
Prelude intermediate shaft if longer than the 90-93 Accord intermediate shaft. Thus, you need a shorter axle if you use the Prelude mid shaft. If you are running into binding problems, use the Accord mid shaft and the shorter 89 Integra axle and that should solve your problem.
BIGBLOCKEK
09-03-2004 09:00 PM
