b20 max over bore
Old Nov 23, 2003 | 05:08 PM
joacim's Avatar
Default b20 max over bore
can i go 85mm on stock sleaves or you recomend to sleaved the block i yust want to save some money for the cams.i have itr cams but i want jun 3.
Old Nov 23, 2003 | 07:03 PM
irev210's Avatar
Default Re: b20 max over bore (joacim)
there are a few people that have 85mm stock b20 sleeves running high compression
Old Nov 24, 2003 | 01:17 AM
Maximus's Avatar
Default Re: b20 max over bore (irev210)
86 would be the max but the walls would be real thin. If you plan to abuse the motor get the sleeves inorder to save money in the long run.
Old Feb 2, 2004 | 10:15 AM
GapxGuy's Avatar
Sushi Buffet Champion
I'm running 85mm on stock sleeves. I take it to 8-8.5K rpm.
Old Feb 2, 2004 | 01:09 PM
HotRodTeg's Avatar
Default Re: b20 max over bore (GapxGuy)
The most that I would ever sleeve a stock b20 block is to 85mm. Not 86mm I would never go 2mm over stock bore. But if you want to be safe and not risk anything I would just get it resleeved then slap in some 86mm slugs. just me thoughts
Old Feb 2, 2004 | 01:34 PM
Kataku2K3's Avatar
Default Re: b20 max over bore (CrazyCompression)
Scott 84.50mm gets my vote
Old Feb 3, 2004 | 04:00 PM
TECH43 RACING INC.'s Avatar
Default Re: b20 max over bore (Kataku2K3)
i've got a ton of b20's running 85's..no problems..but beware..regardless or bore size. b20's have WEAKER SLEEVES than the other b series. the sleeves were casted differently and they split after a while, especially with the increased compression people put in them and the increased rpm. if you can afford it...get a ls block with a cracked sleeve, and get ductile iron sleeves installed, then go 85mm. you will never blow those up. http://www.rsmachines.com . 310-328-5514
xxjonxx4
15
Jan 24, 2013 04:22 PM
Annihilator
Apr 16, 2010 12:31 PM
1990_integra_DA9
Nov 1, 2008 08:27 PM
Lsweez
Dec 23, 2007 09:27 AM
ForceFed Coupe
Jan 4, 2004 06:52 PM
