LS vtec head bolts torque specs one hole in the block might be stripped help
well i have a b18a1 block with 94 gsr head.
heres the problem the previous owner stripped some from the block. well i got the head on and i hand tightened the bolts in this sequence(below) i didnt do it too tight at first being scared i might mess soemthing up just finger tight. i broke my torque wrench(crappy craftsman)
the sequence i tightened them
7 3 1 5 9
10 6 2 4 8
the first time i tightened it number 3 was fine but the second time it wouldnt tighten being too risky i stopped at that and just finger tightened the rest again. well im picking up a tq wrench tomorrow and need specs on how many ft. can anyone assist me. and about the stripped #3 is it ok to drive on that? its semi tight... i want to at least be able to drive it to a machine shop so that they can either heli coil or time sert it.
7 3 1 5 9
10 6 2 4 8
Re: LS vtec head bolts torque specs one hole in the block might be stripped help (mts.)
you need to get the threads repaired first before you go torqueing down the head.
horn12007
19
09-20-2010 06:02 PM
LSVtecHatchback
05-05-2005 03:22 PM
