B series enine question.....help
I have a B series engine, but i don't know what kind it is.
it only says honda motor company on the valve cover.
it looks kinda like this-----> http://www.hmotorsonline.com/shop/images/b18b1.jpg
is there any way i can tell what type it is???
thanks...
thanks...
Re: B series enine question.....help (alergic2fatchix)
that engine you posted the link to is a nonvtec b18b. they are from the integra LS/RS/GS 94+
does the valve cover look EXACTLY like the one in picture? if so, then it is a b18b.
there is an engine block stamp on the block that will give you the exact code, but this doesn't necessarily mean you have vtec or not since you can mate a nonvtec block to a vtec head.
You have there (either) an OBD-2 B18B LS motor from a 96-01 Integra, or a JDM B20B motor out of an 97-00 Orthia wagon.
Read what the block stamp says and you can tell what year the motor is as well.
yup, exhaust side, tranny side theres a stamp on the block... read it. by looking at the intake manifold on that motor, I believe its a B18B... simply because the B20 factory intake manifolds are quite tall.
-Mike
-Mike
thanks alot.
ans also, what is a frankestain motor??? or something like that.
and is the b18b a good engine to work on???
thanks....
thanks....
Frankenstein motor refers to a VTEC head paired with a Non-VTEC block. B18b is a good motor as far as reliability goes and its not bad on power either(compared to similar sized motors by other manufacturers). Lower compression makes them a good canidate for boost (turbo or supercharger). Use the search function and I am sure you can find any info you are seeking.
neve12f0ll0w
05-18-2006 05:38 AM
