Is 1000 to much for an install?
Old Nov 18, 2003 | 01:48 PM
ramz7887's Avatar
Default Is 1000 to much for an install?
A shop wants to charge me 1000 to put in a B16B into a 98 civic 4dr. He told me it was a flat rate to do the install, wireing, change a water pump, timing belt, and clutch. Is this a good deal?
Old Nov 18, 2003 | 02:24 PM
stickercuttingcom's Avatar
Sounds quite steap to me. Take the old engine out and roll it in there, see how much that reduces the cost.
I havent' heard someone paying $1000 for an install..look around and compare prices. Make sure to ask about past experience in swaps, etc.
Old Nov 18, 2003 | 02:56 PM
AL ASPIRATED's Avatar
Default Re: Is 1000 to much for an install? (ramz7887)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramz7887 &raquo;</TD></TR><TR><TD CLASS="quote">A shop wants to charge me 1000 to put in a B16B into a 98 civic 4dr. He told me it was a flat rate to do the install, wireing, change a water pump, timing belt, and clutch. Is this a good deal?</TD></TR></TABLE>
does t include the water pump, timing belt and clutch too? or is dat jus da labor?
i mean if they do a really good job, then i say it worth it. pay alittle more for a better job. "YOU GET WHAT YOU PAY FOR!"
but i usually see people pay around $500=700 for labor though
Old Nov 18, 2003 | 04:25 PM
irev210's Avatar
Default Re: Is 1000 to much for an install? (JDMTyPeRHaTcH)
seems like a pretty good price including parts and what type of clutch.
OEM type R, OEM water pump, OEM timing belt, thats a good deal
Old Nov 18, 2003 | 05:09 PM
ramz7887's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMTyPeRHaTcH &raquo;</TD></TR><TR><TD CLASS="quote">
but i usually see people pay around $500=700 for labor though</TD></TR></TABLE>
Yeah they do a good job plus they will give a warrenty on the labor. I'm also buying the engine from them and they gave me a good deal. As far as that 1000 is just for the labor of installing the clutch,timing belt,waterpump, and valveadjustment. Everyone i talked to says that you should do all of these before putting in a swap though i would like to wait on it so i could save money.
Old Nov 18, 2003 | 05:37 PM
Newman's Avatar
New User
That's actually a rather high labor charge, but it all depends on your area and the shop's competition. For something like that, we charge anywhere from $400-$550 for dropping the motor in and no CELs, depending on the car model for wiring, and throwing on a new timing belt, clutch, water pump, seals, etc (provided to us by the customer) at no extra charge while the motor is still out. Depending on their history & credibility, and what type of swaps they've done in the past, you may want to keep looking around for a better price with somebody who has done similar swaps.
Old Nov 18, 2003 | 05:57 PM
ramz7887's Avatar
Default Re: Is 1000 to much for an install? (Newman)
The shop is http://www.streetsports.com/Ph...e.htm they are based in Nicholasville in KY. I don't think that they have too much competetion. But i know that they have done a lot of swaps and they are geting a new shippment of engines from Japan.
Old Nov 18, 2003 | 06:18 PM
eyeamvic's Avatar
I've seen shops around here do swaps for $400. If you want it done cheap, get yourself a helms manual, rent a engine hoist, and go at it. This board can help with install.
Old Nov 19, 2003 | 11:31 AM
crxtreme89h's Avatar
Do it yourself if you are somewhat mechanically inclined. You will save yourself $1000 and learn something that you can charge $500-1000 for.
Old Nov 19, 2003 | 11:40 AM
quickchris's Avatar
if u lived in s.w. v.a. i would charge 700,,,labor only,,,thats our going rate
Old Nov 19, 2003 | 10:45 PM
Boosted1999Ek's Avatar
Default Re: (quickchris)
my buddy charges anywhere from 300+ to do swaps
Old Nov 20, 2003 | 02:35 PM
Type Wah's Avatar
Default Re: (Boosted1999Ek)
that is pretty expensive for labor...
Old Nov 20, 2003 | 03:39 PM
JTB's Avatar
JTB
Default Re: (Type Wah)
that seems high if you want to take a road trip to wi i will do it for $650 factory trained and certified. alot of swaps done 20-25. that is a rather easy swap!
LAO
Acura NSX
Jun 5, 2008 08:05 AM
Daisysi
Southeast
Jan 8, 2008 06:57 PM
gsrboi80
Aug 18, 2004 10:36 PM
Mattyg2
May 11, 2004 02:07 PM
ShiftDown
Aug 5, 2003 08:28 PM
