00 itr crank pulley vs 99-00 si crank pulley (searched)
Hey everyone. I searched for the difference between the itr crank pulley and the 00 si crank pulley. Honda has a different part number for the two but I want to know if there is an actual size difference. I am recieving an 00 itr shortblock from Honda to put into my 99 si so I need to know if I have to use the GSR crank pulley sitting at the shop or if I can use my 99 si crank pulley. Thanx in advance.
Re: 00 itr crank pulley vs 99-00 si crank pulley (sinatra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinatra »</TD></TR><TR><TD CLASS="quote">Hey everyone. I searched for the difference between the itr crank pulley and the 00 si crank pulley. Honda has a different part number for the two but I want to know if there is an actual size difference. I am recieving an 00 itr shortblock from Honda to put into my 99 si so I need to know if I have to use the GSR crank pulley sitting at the shop or if I can use my 99 si crank pulley. Thanx in advance.</TD></TR></TABLE>
diametrically, they're exaclty the same size. There's really no benefit between the two, they're both identical in purpose, weight, and spec.
More than likely, the reason why there's a different part number between the 2 pulleys, yet their the same damn thng, is because one vehicle is a Honda Civic and the other is an Acura Integra.
The Si crank should fit on an ITR block without problems.
b16crx0062004
09-02-2004 12:27 AM
