E85 finally showed up at the pumps in town...
Regardless of gas mileage, what kind of power could be extracted from using E85 over 93 octane on 11.1:1 compression? I would assume you could use more timing since it is 104 octane. The best part about it is how cool it runs making it ideal for racing. I have an S300 in the garage so it would be easy to switch between tunes.
From what I've read 5-10 HP, but the biggest concern is that e85 isn't regulated as hard as regular pump gas is. Basically meaning and the octane levels could vary slightly so I would push the limit to hard on the timing.
I did some reading and found that E85 has a summer blend and a winter blend. WTF is this coffee? Lol. Is E85 different percentages from station to station or what? The biggest gripe I have about it is that it attracts water very easily. 5-10whp would be a great gain to see, I'm most interested for the cooling factor in a race environment.
The experience I have with e85 is the mix may change slightly but not enough to affect the tune or how the car runs. I have tuned a stock b16, 380HP b16 turbo, 500HP 2.1l GSR all on e85. IMO the gains on a na car aren't worth the additional stops to the gas station on a daily driver. If it's not a daily there is no reason to not go e85. The ONLY downside I have actually seen is the slight reduction in gas mileage. A stock GSR should still get around 23-35mpg in town driving easy though.
11.1 compression ratio in what? Specs on setup? You left that big major factor out...as stated, all motor sees minimal gains across the board, boosted is a whole nother subject..
It's just a bolt on 98+ B18C-R, Toda 4-2-1 header, Comptech Icebox intake, 60MM piping out the back, ID1000cc injectors... my baseline with stock everything was like 173WHP and 124FT LBS or something. Now I have all that and a S300.
krshultz
15
Dec 27, 2001 10:40 AM
