GSR Block with PCT's and Pro3 Cams
i have an GSR Block wos bored to 81,5mm with B16B pistons
Block is B16A with Skunk2 Pro3 Cams
does this Setup work or is the p2v clearence bad !?
CR !?
PR3 head/B18C Block
STD = 12.58636786521145
.25 OS = 12.649248792586258
so i think i have ~12,8 CR
when the p2v clearance not enough is i cant use a cometic headgasket...but which !? .30", .40" or .57"
please help ^^
best regards from Austria
CR !?
PR3 head/B18C Block
please help ^^
Re: GSR Block with PCT's and Pro3 Cams
When you say does this setup work? What are you referring to? Yes your static comp is at 12.8:1, what octane fuel do you plan on tuning it with? Do you have all supporting mods for this setup to flow as it should?
- larger injectors
- larger TB
- Aftermarket IM or ITR by the least
- 2.5" exhaust
etc..can't expect nice numbers or a healthy setup without taking everything into consideration..As far as the P2v clearance, you are probably going to want to have your builder clay the motor to check this. PCT's do have a scary dome height and you mentioned the Pro 3's...
- larger injectors
- larger TB
- 2.5" exhaust
sorry... the rest of the setup -->
B16 ported head
Injectors are 440's
ported 65mm B18C Throttle
ported JDM B18C Intake Manifold
B16 ported head
Injectors are 440's
B16 ported head
Injectors are 440's
it will be tuned on 100oct
B16 ported head
Injectors are 440's
^ This. They'd do you more bad then good with your said setup..everything else looks ok...I'd look into some p30's if your looking to stay OEM
LOL, no comment.
Ok, just trying to grasp this logically.....did you want him to do p30's on Pro3 cams?
And he's going to be on a higher octane....are CTR's still a no no?
I just know now and days people wont do what mikey does or take the time to measure things. So save yourself the hassle.
I'm done with the hating, talking **** or even getting upset on a forum, its no use. Everyone's here to help and learn.
I seriously LOL'd when I read this thread title. There are only a handful of builders I would ever trust to pull this off successfully. I love how MAX compression with the BIGGEST CAMS seems to be the idea of making power for a street car on pump gas.
All Motor Mentor
1 Post
On an NA motor, these are common things to do when trying to make more power. Any piston he uses to get to the compression level he wants, to run those pro 3 cams in an 81mm bore, are going to have a "large dome" on them.
I'm fortunate enough to have another car with high compression and a huge cam that I dont drive everyday.... but its a V8...back to my fuel theory.
I have yet to see someone run pro3's with CTR pistons, just saying.....and i'm in the middle of a CTR with Pro2 build that I plan to run 93 Octane and 104 at the track since well I can get it right down the road from me but 93 octane will have more conservative timing and at the dyno we shall see what 104 does and if power goes up and by how much
GL with the CTR & Pro 2 build. If it clicks it should make good power. I was just making a statement that Full racing cams with 13:1+ compression is not a daily build by most peoples standards. It would be like me driving this every day...
http://youtu.be/VxhbWeCda3Y
I don't care who you are, nothing sounds better than a healthy V8 with a monster cam. OP if you can get your honda to sound like my chevelle, go for it
All Motor Mentor
1 Post
The biggest problem with H-T these days are all the blanket statements being thrown around, about what you can and can't do, without the real world experience to back it up.
13 compression can be done on the streets but not with ctr pistons....im running manleys on my build at 13:1 and so far no signs of detonation....but i did sand dow all the sharp edges and also a forged piston runs cooler...
Its not that they run cooler, there is less hot spots since they don't absorbe heat as much, and ctr can be done and will be done, and I'm going to do it BUT you need to clay/degree your cams and deburring helps with hot spots
A Digital Frontier
Exactly what i was thinking. 13+ compression pistons have very similar dome to the ctr.
