Ever heard of removing the secondaries?
Old Apr 14, 2004 | 10:23 AM
SpeedingHatch's Avatar
Default Ever heard of removing the secondaries?
Another forum I am on, a dude recommended polishing my intake manifold and removing the secondaries. What's the advantage of removing them? Will it throw any codes? Anybody actually done it?
Just some questions, sorry if I sound like a n00b
Old Apr 14, 2004 | 10:57 AM
tiresmoke's Avatar
Default Re: Ever heard of removing the secondaries? (speedinghatch)
unplug the soliniod for the IAB and go for a burn in your car. you won't like it. and that is what it will feel like with out your secondaries.
Old Apr 14, 2004 | 11:44 AM
Micro's Avatar
if you have a GSR car, with a GSR head running on it, i would personally not recommend removing the secondaries. I have a ls/vtec with a gsr head, and if i had the choice, i'd run the butterflies to open when they are supposed to. unfortunately, i don't have a p72 computer, or the knowledge to wire up the butterflies to my computer (again, if i was running a p72). I have mine completely removed, and the low end is hurting, for sure. the car actually starts to pull nicely after 5500 rpm. If you had the secondaries operating, you'll see the improvement as soon as vtec hit at 4400 rpm, and then the secondries open around 5.5-5.6K rpm.
Old Apr 14, 2004 | 11:51 AM
Default Re: Ever heard of removing the secondaries? (Micro)
I have an H22 eg hatch
But in other words, your saying its not worth the time?
Thanks for the help
Old Apr 14, 2004 | 08:45 PM
Micro's Avatar
ok, i hought you meant for a gsr... H22's have the same butteflies...
If you're not running a computer that can operate them correctly, remove them.
Old Apr 16, 2004 | 11:39 AM
dfoxengr's Avatar
basically if you have a 'non-butterfly' computer, take them out. and work the inside of that manifold...or send it to me to do [shamless plug] pm for price
Old Apr 20, 2004 | 01:48 PM
Default Re: Ever heard of removing the secondaries? (hybridvteceg)
I have the P13 ECU
Schister66
Jun 1, 2009 11:41 AM
1993gsrcivic
17
Aug 7, 2007 09:50 AM
bdavis
Mar 9, 2006 06:29 PM
Black R
11
Apr 19, 2005 08:24 AM
lills
Dec 15, 2004 10:37 PM
