b16 swap in 89 crx hf
hello everyone , I need some info for this swap.
I'm installing a b16 in a 89 crx HF.
I was informed to use the spindle rotor. hub assembly from a 90 integra.
Is there any other suspension component that I need? such as control arms etc?
Is it true that the rear trailing arm from the int. will bolt right up to the crx?
Do I need the master cylinder & booster?
The HF motor a pathetic.
with this swap what kind of et's can i pull.
I would appreciate any info.
Thanks
Thanks
