94 GSR swap, Vtec not hitting till 5800rpm why??
The car is a 93 integra Rs
I have it all wired up for Vtec. Vtec solenoid (YEL/GRN) goes to A4 and Vtec Oil Pressure 2 wire (BLU) goes to D6 and Black goes to Ground, knock sensor to the D3. I have the secondary butterfies wired up so that the pink/blue goes to pinout A17 but the other wire was black so I grounded it. But I should have run it to a 12v+. would this cause my problem. also I'm getting a CEL and it is for the ELD (code 20). the other thing is the vacuum stuff that was on the fire wall what do I do with this stuff. I will post a pic later. Also if it makes a differance I'm running a the Rs cable tranny. thanks
Re: 94 GSR swap, Vtec not hitting till 5800rpm why?? (tiresmoke)
doesnt look like a GSR swap, thats a PGMFI IM, its not inverted like the GSR mani?? So is that a pic of your b16 then?
I thought Vtec on a gsr was 4700, I have a chipped p28 and mine is set at 5700. Are you sure you dont have a chipped ecu?
Re: 94 GSR swap, Vtec not hitting till 5800rpm why?? (TODAeg6)
that is not a pic of the swap that is a pic of the vacuum stuff on the fire wall. here is a pic my brother in law took he is a VW lover.
I'm not sure maybe it is a chipped ECU I got the ECU with the engine. It is my cousins car he picked up the engine and ECU. how can I tell if it has been chipped.
Look at the sticker on the side of the ECU housing, is it a P72? If you don't have experience with ECU's, chances are it will be hard to tell if it has been chipped.
Re: 94 GSR swap, Vtec not hitting till 5800rpm why?? (VTECVillain)
It is a p72 ECU I have experience with ECU's. the Vtec should hit around 4500rpm. my question still is what do I do with the vacuum stuff on the fire wall in the first 2 pics. I extended the wires for the MAP sensor to reach the MAP senser on the GRS throtle body but the other stuff looks like maybe a Perge contol solinoid or something.
i am pretty sure VTEC dont hit in a 94 GSR till 5800
at leat that is the case in my bud stock GSR
VTECVillain is correct
vtec crossover is 4400
Secdondary is 5800 I think I found what I was looking for as far as the Vtec engagement it's louder 5800. VTEC is pretty quiet at 4400.... often confused for the IAB at 5800 ...
thanks
thanks
crxricer66
11
03-19-2010 10:07 AM
