Swapped B18c no vtec and bogging, need help
I have a B18c with the gsr harness in a 92 cx. I am running the gsr ecu and switched the right wires, a20 to a17 and switched the 02sensor wire. I'm not getting any cel codes except for the speedsensor, but it's still running slow. The vtec isn't working either. I called the local tuner shop, method motorworks and they told me that a gsr harness wouldn't work. He advised me to just use my cx harness and rig the missing wires. IS that right? what should I do?
Re: Swapped B18c no vtec and bogging, need help (mishimamadness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mishimamadness »</TD></TR><TR><TD CLASS="quote"> He advised me to just use my cx harness and rig the missing wires. </TD></TR></TABLE>
I just finished a OBD1 GSR swap into a 93 integra but post I made may help you out. https://honda-tech.com/zerothread?id=832876
