Head Stud Torque Spec Question
Old Apr 12, 2004 | 12:21 AM
importimage's Avatar
Default Head Stud Torque Spec Question
I have a B20B Vtec Turbo swap. I bought ARP studs and am just wondering if I should follow the ARP torque spec with the moly lube, fire up the car, then retorque or should I drive the car for a bit then re-torque. Finally, when re-torquing, should the car be hot or cold and would the torque spec changed based on if the car is hot or cold.
Old Apr 13, 2004 | 12:51 PM
Default Re: Head Stud Torque Spec Question (importimage)
anyone
Old Apr 13, 2004 | 04:35 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
in my travels i believe that arp's need to be retorqued 3 times before they are correct.
Old Apr 13, 2004 | 05:40 PM
myhatchrips's Avatar
yes 70 ft lbs with arp moly lube. im not sure if its necessary to retorque the head?
Old Apr 14, 2004 | 02:26 AM
Default Re: Head Stud Torque Spec Question (myhatchrips)
Called Arp and they said 65 fl lbs with moly lube. They told me to retorque only once after the initial install and cranking.
avotegra
Dec 27, 2015 01:26 PM
092eg6
Jul 21, 2010 11:32 AM
george34
Feb 18, 2006 05:05 AM
LilCivic04
Aug 6, 2005 06:34 PM
iperez
Mar 12, 2004 11:36 AM
