91 integra / b16a need some info..
doing a swap for a friend..got a front clip from a jdm teg 90-91? not sure (anybody need any rhd stuff ive got it...really cool digital climate control system..)
need to know of anything i might run into, the small stuff like different wiring or anything. ive done a swap into a std 91 hatch b16a and that was a little tricky. from what i see it should be striaght forward.
thanks for any tips.
Re: 91 integra / b16a need some info.. (swaplighter)
I dont know too much about that swap, Im pretty sure you can retain your stock mounts, You might need the brackets off the b16, but wiring wise just add your 4 extra wires to the pr3: knock,vtec oil p, vtec spool, 2nd o2 . The green plug on the B16 is ur primary which I believe is c16
killrB
11-24-2007 03:04 PM
paybac4223
01-18-2004 04:15 PM
civichopeful
08-02-2002 01:53 AM
