JDM H22 into 92 CX Must do's
Hey guys I'm the process of swapping a jdm h22 into my 92 cx, I'm not sparing any expenses so I would like to know what I should do before swapping in. So far I bought new fluids, coolant, oil, tranny oil. I bought new belts accessory and timigng belt. I don't wanna mix match axles so I'm gonna buy some dss stage 2 axles, I just don't know what to do about rad and fan combo? Since some ppl say civic rad just isn't good enough what would clear the front of the engine with enough clearance and enough cooling properties? Any other things I should cover?
on the radiator issue...you can use the stock one but the fan will have to be a thinner than stock one...i used the stock one but there is no clearance...i put a big one on my civic and AEBS told me that it was not necessary... and they are the kings.
Re: (eduardo)
You can ran a del slo dual core radiator with a slim fan with no problems at all
The stock fan does work but is a POS to get to fit and never looks right
VWkila
09-22-2002 09:33 AM
