GSR tranny and 92 ls axles.
Old 04-09-2004, 01:06 AM
ek99's Avatar
Default GSR tranny and 92 ls axles.
I'm using 92 ls axles on my 96 GSR tranny, and there seems to be some oil around the axles and tranny. I know my rack&pinion was leaking, but would it be possible for oil to leak through the tranny seals due to the axles being 92 Ls and tranny being 96 GSR? Thanks
Old 04-09-2004, 04:19 AM
VTECVillain's Avatar
Default Re: GSR tranny and 92 ls axles. (ek99)
It will leak on the driver's side since I assume you would have to be using a 90-93 intermediate shaft if you're using 92 axles. All you need to do is change the driver's side axle seal to a 90-93 Integra seal and it should stop the leak. The passenger side should be fine, no need to change anything there.
dhn
07-04-2008 10:18 AM
hondatuner20
03-19-2006 04:36 PM
fn_phat
05-23-2003 12:54 PM
Quick Reply: GSR tranny and 92 ls axles.
