swaped b16a into 91 civic hatch problems ??????!!?!?!?!
i just did a swap like show above and iam haveing more than one problem the bad vibration iam getting at about 30mph and plus it feels like the thing has no power at all iam thinking that mit have to do with the wireing or someting but if u have any input or info feel free to drop a few lines thanks
Re: swaped b16a into 91 civic hatch problems ??????!!?!?!?! (SOHC Gord)
Have you checked all your suspension bolts? I just looked over mine the other day and my lca castle nuts were a little lose. I havent had the chance to drive it to see if it fixed it thou. How did it drive before the swap? Sure the wheels were flush when torqued?
how is the geometry of the drive shafts?. it is importent that they are at close to the correct geometry. try using a 90-93 integra 1/2 shaft. I ran into this problem with one of the B16 swaps I did
Re: swaped b16a into 91 civic hatch problems ??????!!?!?!?! (tiresmoke)
i mit have to try the 90-93 intermediate shaft sounds like that could be a problem but it all looks fine the length and all but ya never now thanks
You are still having trouble with this what all have you tried to resolve this
sheew finaly got a day off gonna work on it tomarrow ill let everyone know what i come up with
Read This
http://cayotic.com/Axles.html
Im having the same problem as you are, I went and ordered a new axel so Ill let you know how it works out.
well my problem isnt solved yet iam gonna put it all toghter here in a few ill post tonight on how it goes http://cayotic.com/Axles.html theres the link that kicks *** and helped me understand go there for help
i own a 1991 dx hatch with a stock no v-tec motor, looking to drop in a 1991 SI motor in. What will I have problems with if ur sure.
got the 90-93 integra half shaft and it doesnt work iam pissed like a mother ****** it doesnt even sit flush with the block
Re: swaped b16a into 91 civic hatch problems ??????!!?!?!?! (castor troy)
you shouldnt have any problems unless your have the 1.5 then u will have to get a 1.6 ecu witch i have one if u need one and your wireing mit be a little different for the fuel injectors and what not all the sensors should be the same probably be easyer to get a wireing harness for the 1.6 otherwise thats it well that i can think of at the moment good luck with the swap if i think of anything else ill let u know
SOHC Gord
05-03-2004 05:55 PM
