i noticed the install guy put a p72 in my h22a civic is that ok?
Location: In the heart of the ghetto of the, Suburbs NYC
Re: i noticed the install guy put a p72 in my h22a civic is that ok? (turbogixxer)
chip? what chip..and why would you chip it..just curious, as i am going this route myself
Re: i noticed the install guy put a p72 in my h22a civic is that ok? (92hybridAccord)
anybody respond? i will be getting either mugen/spoon chip but why? and is the p72 stock ok by its self the car seems to be running great!
Re: i noticed the install guy put a p72 in my h22a civic is that ok? (fastest)
It is more like a safe guard
Do you have to chip it? No but you may run lean
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastest »</TD></TR><TR><TD CLASS="quote">anybody respond? i will be getting either mugen/spoon chip but why? and is the p72 stock ok by its self the car seems to be running great!</TD></TR></TABLE>
It may run great right now but over time you may notice fuel issues (like being too lean or what not) and thats basically because your runnin the p72 fuel maps and not the correct p13 fuel maps. Chippin the ecu will give you the correct fuel maps and will also allow for other adjustments depending on your program.
I myself have a chipped p28.
Re: i noticed the install guy put a p72 in my h22a civic is that ok? (1993sir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993sir »</TD></TR><TR><TD CLASS="quote">i think you got your ideas all mixed up, if you run a chipped ecu, it is more risky then running a stock gsr ecu. that should run the motor perfectly. cuz with a chipped ecu your not getting the correct program your getting a basic program for fuel and timing curves. there is rarely a real spoon or mugen ecu, and if you think you got one, then good luck your special. i can also take my computer up load the program off your "spoon chip" and change the vtec crossover and the redline and make it "pull harder then a "mugen chip".</TD></TR></TABLE>
explain why gsr maps are better?
Re: (fastest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastest »</TD></TR><TR><TD CLASS="quote">y not gsr for h22?</TD></TR></TABLE>
Because the fuel maps are for smaller injectors so you will be running lean, especially at the top end when you are in vtec where the h22 uses a lot of fuel, also you will have a huge dip in power when vtec kicks in because the gsr ecu opens its butterflies way later then the h22 does.... so vtec will kick in and your butterflies will still be closed until about 6000 rpms and you'll be starving for air...
DYNO-PRO
Location: SoCal I.E 909, CA, where we innovate not immitate
Re: (MusclecarGuyhasHonda)
in my opinion i would run the gsr ecu stock and add a apexi VAFC, dyno tune it to check air fuel and adjust vafc accordingly
