Grey plug in EF
Old Apr 15, 2004 | 05:01 PM
SeanEF's Avatar
Default Grey plug ZC in EF
Is it worth the rewiring hassle?? The motor i was supposed to get (1st gen) turned out to be a grey plug...
Modified by Sulli at 9:27 PM 4/15/2004
Old Apr 15, 2004 | 08:13 PM
krazie1's Avatar
BANNED
Default Re: Grey plug ZC in EF (Sulli)
why u tripping it is better to have obd1
haven't searched around
I am hassling the convert has we speak
u lucky dogg
Old Apr 16, 2004 | 12:40 PM
Colin's Avatar
its actually really easy. there isn't really any "rewiring" pretty much only the adding of wires, and swapping a couple connector plugs......assuming you're using a jumper harness. And cost wise it would probably be worth it for you. You'd just have to buy the jumper harness. If you were gonna stay obd0 you'd have to go thru the hassle of finding an obd0 ecu and distributor...which sometimes can be more trouble than its worth. Plus with obd1 you won't run into the secondary O2 sensor issues.
http://www.g2ic.com/forums/showthread.php?t=86612
tyvtec23
16
Nov 11, 2011 02:44 PM
freezy
13
Apr 11, 2011 07:32 PM
Novtecdohc
Aug 18, 2005 06:32 PM
teg4life
Oct 14, 2004 11:22 AM
mugenintegra16
Apr 8, 2004 10:26 PM
