b20 vtec parts list
Old Apr 11, 2004 | 09:08 PM
showtymers619's Avatar
* B A N N E D *
Default b20 vtec parts list
so far i have
b20 block
complete b16 head
i need a vtec lines from block to head..
what timing belt do i use and what waterpump?
Old Apr 12, 2004 | 12:12 AM
JDMorgan's Avatar
you need: oil lines and fittings like u said, dowels, ls headgasket, vtec oil pump, water pump, tensioner and spring(good to replace anyways.), vtec timing belt, and also itr head bolts. i just buy itr parts since it has the same head and deck height. thats really the only vtec motor that you can use almost anything off of. im pretty sure you can use gsr pumps and belt too, but when you are there buying parts it is easier if you can get everything from the same car. less searching for parts numbers.
Old Apr 12, 2004 | 06:04 AM
* B A N N E D *
Default Re: (KraZEtEggIE)
cool thanks.. i was just mainly concern on which water pump and belt to use.. i got everything else
Old Apr 12, 2004 | 05:54 PM
Patch's Avatar
Default Re: (ShowTymers619)
If you're running OEM cams, then get an ITR water pump and timing belt.
Old Apr 14, 2004 | 11:01 PM
* B A N N E D *
Default Re: (Patch)
itr belt same as b16/2000 si?
Old Apr 15, 2004 | 12:17 AM
JDMorgan's Avatar
no b16 is shorter. stick to itr ****. b18c1/gsr will work too but as i said b4 its easier to just specify 1 car and keep usin it for everything. i normally say 97 itr.
Old Apr 16, 2004 | 11:37 AM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patch &raquo;</TD></TR><TR><TD CLASS="quote">If you're running OEM cams, then get an ITR water pump and timing belt.</TD></TR></TABLE>
that has nothing to do with anything
go cheap and get ls water pump and t-belt. they mark up for the R...dont you know...
Old Apr 16, 2004 | 04:04 PM
nickgmiller04's Avatar
Default Re: (hybridvteceg)
i hope he's being sarcastic.
ive researched and found that you need a gsr waterpump/timing belt. they go together. ls pump/ls belt
but the gsr/itr works better at high rpms.
i plan on building an ls/vtec and this is the conclusion that ive come to about pumps and belts
Old Apr 16, 2004 | 04:31 PM
dfoxengr's Avatar
Default Re: (nickgmiller04)
me being sarcastic? i said ls pump and t-belt.
Old Apr 16, 2004 | 05:03 PM
* B A N N E D *
ok .. ? .. i guess ill go with the gsr pump and belt..
Old Apr 16, 2004 | 06:54 PM
Patch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">
Uh, it doesn't? What if he's running Toda B's or C's, should you run a stock timing belt on those cams? Hence why I said, OEM cams.
Old Apr 16, 2004 | 08:12 PM
zensoku207's Avatar
do stock timing belts usually break with upgraded cams?
Old Apr 16, 2004 | 09:26 PM
JDMorgan's Avatar
no. i have never heard of 1 belt breaking from upgraded cams. the only reasons people upgrade timing belts is either for bling factor or because they have insane hp....no na car should need an aftermarket tmiing belt ever unless it has a deckplate since it would need a custom size.
Old Apr 16, 2004 | 10:12 PM
zensoku207's Avatar
gracias senor
Old Apr 17, 2004 | 11:59 AM
Patch's Avatar
Toda cams are notorious for shredding OEM timing belts.
Old Apr 17, 2004 | 12:13 PM
zensoku207's Avatar
Interesting.......
Old Apr 23, 2004 | 10:34 PM
kron0ne's Avatar
Default Re: (zensoku207)
whatever oil pump you get use taht timing belt type r oil pump type r timing belt
Old Apr 24, 2004 | 02:15 AM
tinkerbell's Avatar
Default Re: (lsi crx)
the poor dude would have been better off searching for a week than reading this bullshit.
Old Apr 28, 2004 | 06:28 PM
kron0ne's Avatar
Default Re: (tinkerbell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tinkerbell &raquo;</TD></TR><TR><TD CLASS="quote">the poor dude would have been better off searching for a week than reading this bullshit. </TD></TR></TABLE>
Greg S.
Old Apr 28, 2004 | 07:22 PM
JDMorgan's Avatar
Default Re: (Patch)
what the **** are you talking about? you are a ****** idiot. i agree with tinkerbell, the creator would be better off researching himself rather than reading this bullshit. i also find it funny that you guys are saying use the timing belt from the same engine as the oil pump when the oil pump gear is removable, keep the oil pump gear, waterpump, and timing belt the same. once again, patch wtf are you talking about. lets see some links to stories of toda cams snapping timing belts.
Old Apr 28, 2004 | 07:34 PM
Patch's Avatar
https://honda-tech.com/zerothread?id=759776
https://honda-tech.com/zerothread?id=838980
https://honda-tech.com/zerothread?id=295152
https://honda-tech.com/zerothread?id=465643
Don't you feel stupid? Sorry that I actually know that I'm talking about. Get off my nuts, your title suits you well.
Old Apr 28, 2004 | 09:53 PM
Ls-Rturbo's Avatar
Default Re: (Patch)
haha comidy
Old May 2, 2004 | 04:33 PM
tinkerbell's Avatar
Default Re: (VtecKillsDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKillsDA &raquo;</TD></TR><TR><TD CLASS="quote"> and i dont know why he said use a ls head gasket becasue b20 pistons are bigger and it would make sence to be to use a b20gasket but i could be wrong forgive me if i am. </TD></TR></TABLE>
no need for forgivness, you are right.
adamlightweight
Nov 15, 2017 08:41 AM
kevin7200
Mar 30, 2014 12:04 PM
ekturbohatch22
May 11, 2007 07:25 PM
94turbolude
Aug 18, 2003 01:07 PM
avividmemory
Jan 9, 2003 03:03 PM
