94 GSR secondary butterflies help??
How do I wire these up? I have the P72 GSR ecu I just need to know how to wire up the sensor under the intake manifold. what ECU pinout do I go to?
Re: 94 GSR secondary butterflies help?? (tiresmoke)
The IAB uses a round 2 prong connector plug. The color coding will depend on the engine harness you use. If you used the GSR harness you will connect PNK/BLU to A17 and the YEL/BLK to any 12V+ YEL/BLK wire from the IACV, injectors, etc - these all go to the 12V+ ECU pinouts A25 and/or B1. If you used the stock harness or one that doesn't have a plug for the IAB, you need to add the plug. Just use any standard round 2 prong connector plug and wire it up the same way.
fibereater
05-05-2010 10:10 AM
Si-Yaaa!
06-20-2003 10:45 AM
