WHAT DO i DO WITH THIS
Old Apr 13, 2004 | 11:03 AM
tiresmoke's Avatar
Default WHAT DO i DO WITH THIS
THE SWAP IS A 94 GSR INTO A 93 INTEGRA RS I JUST NEED TO KNOW WHAT IS THIS AND WHAT DO I WITH IT. WHERE DO THE VACUUM LINES GO AND STUFF. THANKS
Old Apr 13, 2004 | 03:07 PM
Myh4tch's Avatar
Thats your map sensor, im pretty sure that you just leave it as is... Even though i think the GSR swap will come with one, you can use the one shown.
Vacume linkes run to the I/M if im not mistaken
Old Apr 13, 2004 | 04:12 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: (1cleanEG)
Actually if it is a 94 gsr motor going into the car then remove the entire mess that you have in the pic. the extend the wires on the 3pin conector that used to plug in there. it will now go to the map sensor located on the top of the gsr t-body.
Old Apr 14, 2004 | 03:06 AM
tiresmoke's Avatar
Default Re: (HOOKUPS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">Actually if it is a 94 gsr motor going into the car then remove the entire mess that you have in the pic. the extend the wires on the 3pin conector that used to plug in there. it will now go to the map sensor located on the top of the gsr t-body.</TD></TR></TABLE> That is what I did and it works perfect Thank you. I just wanted to make sure I didn't make a mistake.
gursh d
Oct 27, 2007 03:59 PM
Honda_RN
Jul 2, 2005 08:05 PM
91crx but i heard vtec
Dec 12, 2003 11:49 AM
HKSone
Oct 29, 2003 02:08 AM
