leaking something need help
Old Apr 20, 2004 | 01:03 PM
hatchmonkey92's Avatar
Default leaking something need help
i have a 92 hatch with a ls swap. i went out to my car and noticed there was a leak by the spot underneath it. i looked under the car and i realzed i can see my flywheel. right where the block meets the tranny, is this right?
Old Apr 20, 2004 | 01:24 PM
D Grade's Avatar
Default Re: leaking something need help (hatchmonkey92)
What is it thats leaking? Smell? Color? Be more specific so we can help you.
Old Apr 20, 2004 | 02:55 PM
Default Re: leaking something need help (Dieselboys MK3)
it looks like new oil, smells different though. the leak is more towards the passenger side i think it might be from the tranny. what does manual tranny fluid look like and smell like.
Old Apr 20, 2004 | 03:15 PM
JDM EJ1 95's Avatar
smells somewhat like coffee mixed with ***... looks red well at least the stock honda stuff does. and if you see your flywheel that means that your tranny isnt bolted up all the way or what?
Old Apr 20, 2004 | 04:17 PM
Default Re: (JDM EJ1 95)
i took some pics
here is where i was talkin about seeing the flywheel...
this is from behind the front passenger side tire...
this is the drain bolt, im pretty sure this was were it was leaking from cause when i tried to turn it spun freely...
i tightened it as tight as possible by hand... this is another angle of it...
Old Apr 20, 2004 | 04:22 PM
Echo7847's Avatar
Default Re: (hatchmonkey92)
You're missing the lower clutch cover.
Old Apr 20, 2004 | 04:29 PM
saleensolution's Avatar
Default Re: (Echo7847)
yeah your missinf the dust cover, it keeps stuff from going up in the fylwheel. but it doesnt cause anything to leak. the other pics looks like the drain for your tranny try tighten it up
Old Apr 20, 2004 | 04:51 PM
Default Re: (saleensolution)
yeah i figured there was supposed to be a cover... thanks for the help
Old Apr 20, 2004 | 06:53 PM
TOFU.man's Avatar
Fluid right here look like its comming from where the flywheel is too. or am i just seeing things if it is i would check the rear main seal it may be leaking.
B16CivicEX
15
May 29, 2006 07:26 AM
DEVIN22CBR
Apr 17, 2003 09:13 AM
torkcm
Apr 9, 2003 10:20 AM
EKHappy
Dec 12, 2002 11:58 AM
