h22 into 96 ej?
Old Feb 17, 2005 | 12:24 PM
knockout's Avatar
Default h22 into 96 ej?
Ive been looking up some stuff about this swap, I have a 96 ex (ej) and I want to swap an H22A into it. My car is OBD2A and I was wondering, should I buy the OBD2 H22, or the OBD1 H22, and while Im on that subject, I heard of some people switching the OBD of their cars (because OBD2 cannot be chipped?) just wondering how that works, thanks you for the input...
Old Feb 17, 2005 | 01:24 PM
knockout's Avatar
Default Re: h22 into 96 ej? (knockout)
Old Feb 17, 2005 | 01:40 PM
knockout's Avatar
also, will the hasport motor mounts fit into my car (the 96-00 ones)
Old Feb 17, 2005 | 07:55 PM
Turbogixxer's Avatar
You need to look into smog. You cant put a old motor (different OBD ECU) in a newer car. They will fail you.
To answer your answer, yes, OBD1 is easier to tune with (a lot more programs).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knockout &raquo;</TD></TR><TR><TD CLASS="quote">also, will the hasport motor mounts fit into my car (the 96-00 ones)</TD></TR></TABLE>
Yes, the EK ones will.
Old Feb 24, 2005 | 02:31 PM
Evil-EK's Avatar
Default Re: h22 into 96 ej? (turbogixxer)
If your car is a 96-98 you need to purchase a 96 and up swap. Not for emissions reasons but for wiring simplicity. If you get a 96 h22a and you combine your 96-98 ex harness with the 96 h22 harness the ex harness will plug up to the prelude ecu. If you decide to convert the car back to obd1 later on you can just buy an adapter harness from boomslang fabrication and an obd1 ecu. When it is time for you to go through emissions you just unplug the obd2-obd1 adapter and install your obd2 ecu. Sorry for rambling and hope this helps.
Mr_Wiggles
Aug 3, 2014 11:32 PM
knockout
Feb 17, 2005 05:05 PM
ApexOne
Aug 23, 2004 11:12 PM
ProjectH22Accord
Mar 6, 2004 02:57 PM
MidoriEK4
Jan 5, 2004 02:35 AM
