ls/ vtec questions
Old Feb 21, 2005 | 08:21 AM
kevslive95's Avatar
Default ls/ vtec questions
i hear that you should run oil squirters in an ls block when not using forged pistions. How do you run them if there is no place to mount them or no oil feed to them? Are they even needed if i'm only going to be revving to 8K rpms? Another question: Are ls rods the same size as itr rods?
Old Feb 21, 2005 | 05:15 PM
Hapexamendios EJ8's Avatar
Default Re: ls/ vtec questions (kevslive95)
i believe that oil squirters will not fit right into the ls block because the crank is bigger (correct me if im wrong) and no the rods are not the same size
Old Feb 22, 2005 | 10:56 AM
kevslive95's Avatar
Default Re: ls/ vtec questions (Hapexamendios EJ8)
what has to be done to the ls rods to make them work with itr pistons
turbodcxbro
25
Jan 7, 2010 07:30 AM
andrewk
Oct 31, 2007 04:15 AM
k e v i n
Jul 17, 2006 12:25 PM
Shiro Z31-T
Feb 12, 2005 02:46 PM
EFin' Kyle
Sep 22, 2004 04:19 PM
