2000 GS-R dash into a 95 civic hatch?
Does anybody know if this will fit? Is there any wiring issues? Your input will be greatly appreciated!
Re: 2000 GS-R dash into a 95 civic hatch? (Spoonin)
Yes I have done them a couple of times. You will need the entire dash and harness from the Civic and Integra and the integra center console to finish the Install as well as the brackets and blower assembly from the Integra. You can get away with using just the upper vents off of the Integra but it is much easier to replace the whole thing. You will have to modify the outer edges of the Integra dash (Under the Dash) where it meets up with the civic mounting points with a dremel. You will also have to modify the door panels and the Steering column upper support to fit the cluster in. Sorry for lack of pics (Not sure how to post them) I always watch this site but never had a reason to post until now. You will probably have to keep your civic defrost switch because using the Integra one will require a lot of rewiring. I can't remember which wires they are but you will have to switch a pin or two in the main harness to get the Cluster to work properly. The first one I did took a day to do but I can do them in about three to four hours now.
I will check this post later on today to see if you have any other Q's
Hope this helped a little. It looks Amazing when it is finished.
Re: 2000 GS-R dash into a 95 civic hatch? (spdosnd)
Was there any wiring issues? Does any of the harness plug into each other? or do I have to do a lot of crimping and soldering?
Here is a few pictures of mine. did it about a month ago. i used the civic dash harness, and the plugs from the integra harness, a roll of solder and 6 packs of shrink tubing. most of the wires on the civic harness match up to the wires on the integra plugs, but there is definetly some wiring issues. the cluster has to be completely rewired. pretty much everything has to be rewired to fit the intrgra dash except for hte climate control. check out the pics though, its definetly worth the trouble. this is in my 95 hatch.
Re: 2000 GS-R dash into a 95 civic hatch? (B18C1 Civic EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1 Civic EG »</TD></TR><TR><TD CLASS="quote">Here is a few pictures of mine. did it about a month ago. i used the civic dash harness, and the plugs from the integra harness, a roll of solder and 6 packs of shrink tubing. most of the wires on the civic harness match up to the wires on the integra plugs, but there is definetly some wiring issues. the cluster has to be completely rewired. pretty much everything has to be rewired to fit the intrgra dash except for hte climate control. check out the pics though, its definetly worth the trouble. this is in my 95 hatch.
Do you mean that you used the plugs from the Integra and just color matched the wires on the civics harness?
Re: 2000 GS-R dash into a 95 civic hatch? (hondaZvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic »</TD></TR><TR><TD CLASS="quote">search this topic. there are a ton of threads on this swap. </TD></TR></TABLE>
yeah. that is how i figured out how to do mine. its not hard to do.
Re: 2000 GS-R dash into a 95 civic hatch? (DavidR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidR »</TD></TR><TR><TD CLASS="quote">what about the door panels? Show us them!</TD></TR></TABLE>
you can kind of see the door panel in the first picture on the diver side. there just si door panels cut out. the door panels were actually the next thing on my list of things to do, just dont have the time.
Re: Re: (Racer X.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racer X. »</TD></TR><TR><TD CLASS="quote">Nice dash swap </TD></TR></TABLE>
wanna buy it?
wanna buy it?
I didnt have to cut my door panels.... its a tight squeeze, but i used CX door panels in a SI... and it worked out pretty well... the only thing i had a problem with were my blinkers when i pulled them from the teggy....
Re: 2000 GS-R dash into a 95 civic hatch? (kblus711)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kblus711 »</TD></TR><TR><TD CLASS="quote">I didnt have to cut my door panels.... its a tight squeeze, but i used CX door panels in a SI... and it worked out pretty well... the only thing i had a problem with were my blinkers when i pulled them from the teggy....</TD></TR></TABLE>
what was the deal with the blinkers?
AIWFCIATR
09-20-2004 11:07 AM
KillerBee18
03-02-2004 10:45 PM
