2000 gsr into a 1995 LS
Has anyone swapped a OBD2B GSR into an OBD1 LS?
I've searched and searched and still have not found exactly what I need. Will a obd2b engine wiring harness plug straight into an OBD1 firewall wiring harness with the wires matching up? Making it jsut a normal vtec to nonvtec swap. I have an OBD1 ecu and know that i need to run the vtec pressure, vtec solenoid, IAB, and Knock wires, just want to know if there is anything else needed to because of the OBD differeces.
Modified by nonvtec at 3:19 PM 2/21/2005
