My "thoughtful" build..........LS/VTEC oem
basically a OEM build, after researching a bit this is what I've started with, let me know what you think.........should something be used in place of something etc, thanks!
i've got a 1999 SI
B16A2 head..........depending compression maybe mill it to bump compression
CTR or 99+ ITR cams
LS rods w/ pins
ITR pistons............with rods a pistons I'm looking to see if maybe just replace them with aftermarket depending price difference between OEM and aftermarket
ARP head studs
CTR/ITR valves springs retainers (if ITR will work with my head)
AEM short ram
2.25-2.5" exhaust
header undetermined at this point
Stage 3 clutch
9-12lbs fly
Thoughts of the setup so far? Approx HP/TQ #'s? Thanks for the help, I'm learn'n and prob forgot a few things!
i've got a 1999 SI
CTR or 99+ ITR cams
LS rods w/ pins
ARP head studs
AEM short ram
2.25-2.5" exhaust
Stage 3 clutch
9-12lbs fly
Re: My "thoughtful" build..........LS/VTEC oem (tthomass)
forgot:
Cam gears of some sort
Hondata and tuned at InlinePro
Modified by tthomass at 8:26 PM 3/3/2005
JDM-siRII
54
04-29-2008 09:39 PM
BI8B
08-15-2003 11:58 AM
