LS/VTEC Electrical Problems
Old Feb 26, 2005 | 05:07 PM
racinategra's Avatar
Default LS/VTEC Electrical Problems
Ls Vtec swap in 91 Integra, runs good, started having minor electrical problems that annoy the hell out of me. Rear Defrost doesn't work. INT mode for windshielf wipers doesn't work all the time (if it does its usually just on LOW instead of intermittent) and I get annoying warning beeps...as if i had left the door open or disconnected the seatbelt. HELP
Old Feb 26, 2005 | 05:08 PM
Default Re: LS/VTEC Electrical Problems (racinategra)
PS. It is OBD0 if that helps with a chipped PR3 ecu
Old Feb 27, 2005 | 06:11 PM
NVturbo's Avatar
O.G. triple O.G.
ECU's dont' run the rear defrosters...or other electrical parts (windows, pwr dl, etc.). You might have wired something wrong..recheck your connections again.
Old Feb 27, 2005 | 10:29 PM
b16ek's Avatar
Default Re: LS/VTEC Electrical Problems (NVturbo)
did u check all your fuse?
Old Feb 28, 2005 | 05:44 PM
VTECVillain's Avatar
It sounds to me more like a dash harness electrical problem. Did all of these problems suddenly occur right after the swap?
kylesmith3251
Sep 26, 2010 08:31 AM
im_inn0c3nt
Engine Management and Tuning
11
Sep 2, 2009 12:15 PM
ericstypeR27
Dec 19, 2008 06:39 PM
nelsonb16
Sep 24, 2007 04:49 PM
Pnoyej6
Jan 17, 2007 05:50 PM
