reliablility of ls/vtec
Old Feb 16, 2005 | 12:21 PM
SpOoNisMyFriEnD's Avatar
Default reliablility of ls/vtec
Im new to the import scene....i am lookin at a car that has a ls/vtec setup. the guy has put in a b18b block/gsr head. the head has been ported and polished, toda cams,edelbrock(sp) intake, etc. i have just heard that these setups eventually become unreliable. is this truth or myth? more info on this setup would be great. the motor is in a 96 hatch.
thank you
Old Feb 16, 2005 | 12:24 PM
what is the reason for their ability to be unreliable?
Old Feb 16, 2005 | 12:30 PM
Hapexamendios EJ8's Avatar
Default Re: reliablility of ls/vtec (pebblepusher101)
way over on the right side of your screen lies the answer (search)
Old Feb 16, 2005 | 12:34 PM
thanx....
Old Feb 17, 2005 | 05:10 AM
VTECVillain's Avatar
Default Re: (pebblepusher101)
The LSVTEC and CRVTEC get a bad rep because in most cases where they are considered "not reliable" the motor wasn't built properly. The nonVTEC block internals were never meant to see 8K RPM's all the time so of course they aren't going to last long if you rev them all day. If built right with the proper internals, there is no reason that one would be any less reliable than any stock Honda motor.
Old Feb 21, 2005 | 04:48 AM
StorminMatt's Avatar
Default Re: (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">The LSVTEC and CRVTEC get a bad rep because in most cases where they are considered "not reliable" the motor wasn't built properly. The nonVTEC block internals were never meant to see 8K RPM's all the time so of course they aren't going to last long if you rev them all day. If built right with the proper internals, there is no reason that one would be any less reliable than any stock Honda motor.</TD></TR></TABLE>
Of course, the real problem with buying a car with an LS-VTEC is not knowing whether the motor is properly built or not.
Old Feb 21, 2005 | 08:11 PM
5STAR3's Avatar
Default Re: (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">
Of course, the real problem with buying a car with an LS-VTEC is not knowing whether the motor is properly built or not.</TD></TR></TABLE>
very true.
the only way i would buy it is if he had it done at a shop and they backed up their work.
bweezy615
Jun 20, 2008 01:29 AM
gvc3k
12
Jan 20, 2006 06:16 PM
Spoogen_1
76
Jan 7, 2005 01:26 PM
4door_gsr_ftw
May 13, 2003 11:30 PM
imonkie
Oct 2, 2002 11:13 PM
