ls vtec problem
Old Feb 27, 2005 | 12:58 PM
turbo_b16_ex's Avatar
Default ls vtec problem
i put an ls in my si and i have a few problems and i hope ill get some good answers. the b16 had arp headstuds, i bought the ls vtec dowel pins, and an ls headgasket. the shop dragline pro told me im suppost to use a ls head gasket, so i bought it and when i started putting it on, the dowel pins would not go through the gasket. so i stuck the ls pins on there torqued everything down.... it runs now but it smokes like hell, i believe that the water is getting in the cylinder because when i open it up, it looks wet.
Old Feb 27, 2005 | 01:49 PM
NJIN BUILDR's Avatar
Default Re: ls vtec problem (turbo_b16_ex)
The ls gasket is right.If you don't buy the ge head gasket you need to open up the dowel holes in the gasket to use the ls/vtec dowels.You should also have b18c head studs,the b16 are too short.
Glenn
Old Feb 28, 2005 | 03:13 PM
the b16 studs go on, but the threading doesnt go through the stud. i read on sportcomp.com you can use either b16, or b18c studs
nightshift_rolla
Oct 1, 2008 06:44 PM
lsVman
Jun 15, 2005 09:15 PM
civicswap
Jun 4, 2005 06:44 PM
7rrivera7
May 25, 2003 01:34 AM
