what head gasket for CTR pistons into b18c?
Old 02-19-2005, 11:42 PM
neeks's Avatar
Default what head gasket for CTR pistons into b18c?
i just bought a stock head gasket for my gsr that has ctr pistons in it...
you think itll hold up or should i get another one??
and yes i searched =P
Old 02-20-2005, 12:24 AM
reactiondc2's Avatar
Default Re: what head gasket for CTR pistons into b18c? (neeks)
it will hold up but i hope you are planning on race gas cause your compression is gonna be up there a lil ways
Old 02-20-2005, 01:09 AM
neeks's Avatar
Default Re: what head gasket for CTR pistons into b18c? (reactiondc2)
err i was hoping on 87 octane @ rotten robbies =x
Old 02-20-2005, 02:47 AM
THEUSED's Avatar
87 Octane + CTR Pistons = Detonation
Old 02-20-2005, 10:47 AM
neeks's Avatar
Default Re: (THEUSED)
dammit!
ok so its safe to say that the stock head gasket will be cooL as long as i use premium gas...
buuuuuut in the long run itll be cheaper to buy a thicker/aftermarket head gasket and spend a little less on gas...
so which one would you recommend?
thanks for your replies btw
Old 02-20-2005, 12:27 PM
THEUSED's Avatar
CTR's in a GSR will yeild around 12 to 1, with a stock headgasket, your best bet would be to run ITR's which yeild about 11.4:1 but you'd stilll need to run some good gas, aren't stock GSR's suppose to take like 89 or higher?
Old 02-21-2005, 06:36 AM
he should read the post about the compression ratio of ctr pistons...its right on top in the all motor forum...if i remember right the compression ratio with ctr's and a p72 head is like 12.5 or higher
Old 02-21-2005, 01:48 PM
Katman's Avatar
a stock head gasket will work.
If you want to lower your compression a little, try a thicker than stock headgasket by Cometic.
HamiltonRex
17
02-15-2005 08:49 AM
awdriscol4
01-07-2005 06:35 PM
TheOne
12-11-2003 06:19 PM
Propulsion
11-03-2003 09:30 AM
Teepo
11-07-2002 08:28 PM
Quick Reply: what head gasket for CTR pistons into b18c?
