swapping a jdm b16 into a 92-95 civic coupe
what's the difference between swapping a jdm b16 into my car than a usdm b16? like what would i have to do to put the jdm one in that i wouldn't have to do with the usdm one. thanks guys
HT Order of Merit
Re: swapping a jdm b16 into a 92-95 civic coupe (93civcoupe)
You would have less to deal with installing the JDM one. It bolts in and you add three wires, (assuming its a DX), VTEC, VTEC Oil Pres, and Knock. Thats it. You would eliminate your EVAP system. If you went USDM you would have to get an ODB1 out of a Del Sol to be a true bolt in swap. Otherwise your using one out of a 99+ Si which is ODBII, and you will have to use a jumper harness to bring it to ODBI.
graveltravel
10-12-2005 08:02 PM
anothersickhatch
08-14-2004 06:58 AM
