Some help for my D15b ek swap Please
ok i swapped a D15b into a shell that i got for cheap. the wire harness i am using is a modded CX wire hareness ( wired for VTEC that is) everything went in fine I tried to start it and it was turning over a couple times and since it wouldnt start i stopped and tried to check my grounds and spark, but once I tried it again it wont even turn over now. The check engine light comes on very dim and nothing happens the only noise you here is a little click but nothing. I look at the ECU and noticed that there are only two plugs that plug into the ECU I am not very familiar with the 0bd2 but I was told that there needs to be three plugs that i only see two coming from the harness and none others i have looked under the dash and nothing doesnt looks like it has been cut off either. Any help is greatly apprecieated... THe ECU is a P2P... the car is a DX and the engine harness is from a CX.... PLEASE HELP
davefromPA
17
08-05-2008 09:33 AM
