Converting to OBD2 posible?? EG4
I have a EG4 with D15b7 engine with DPFI, and I'm going to swap that for a 2000' ITR B18C5 with OBD2.
Is there any problems in useing the OBD2 wires in my car? I'm thinking of instruments and other stuff that connects to harness between ECU and Motor.
Am i way out, or will this work good?
Do i have to soldier or change any plugs, or is it just plug and pray?
Getting the 5 lug conversion from tha same car, any problems in not useing the ABS??
Many Thanks'
Kristian Moe
Norway
Many Thanks'
Kristian Moe
Norway
Re: Converting to OBD2 posible?? EG4 (khmoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khmoe »</TD></TR><TR><TD CLASS="quote">I have a EG4 with D15b7 engine with DPFI, and I'm going to swap that for a 2000' ITR B18C5 with OBD2.
Many Thanks'
Kristian Moe
Norway</TD></TR></TABLE>
wth faaa?? DPFI in an EG??? weird....never seen/heard of that before.
You can go OBD2 if you want via OBD1->OBD2 jumper harness adaptor (which i sell).
You got pics of your engine bay at all? I'm curious in seeing factory DPFi in an EG chassis... I woulda thought Honda did away with DPFi w/the EF series...
Many Thanks'
Kristian Moe
Re: Converting to OBD2 posible?? EG4 (Katman)
That is the coversion from my ECU plug to the new OBD2b ECU plug you have.
Do you know if there is an easy way of converting to OBD2 from the car and onto the motor?
Don't have a camera that works in front of me, but it looks like the old EF with DPFI
SHG_EasyE
11-15-2005 07:06 PM
