B18C5 obd2b into a EG4!! Help!!
I'm going to buy a b18c5 from a itr 2000 JDM OBD2b, i have research and found out that the harnes from the motor should connect to the OBD1 in the car.
But what should i use on the ECU part. i'm getting the ECU from the same car, but can i use it with a wireing conversion harness??
Help me.
Help me.
* B A N N E D *
Re: B18C5 obd2b into a EG4!! Help!! (khmoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khmoe »</TD></TR><TR><TD CLASS="quote">I'm going to buy a b18c5 from a itr 2000 JDM OBD2b, i have research and found out that the harnes from the motor should connect to the OBD1 in the car.
Help me. </TD></TR></TABLE>
Its completely plug and play.
Ecu is up to you, I would just go w/ a chipped p28 if you're on a budget. Unless you have the cash for hondata.
I have heard that the OBD2b ECU has a security key thing is that true, or not?
Were do i buy harness or a p28 that is chipped??
Thanx for replys
Thanx for replys
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khmoe »</TD></TR><TR><TD CLASS="quote">I have heard that the OBD2b ECU has a security key thing is that true, or not?
Thanx for replys</TD></TR></TABLE>
Yes obd2b has immobilizer, I can remove it for you.
Harness.. most local import shops should stock them or here on the boards.
Some sponsors will hook you up w/ a complete setup.
Re: B18C5 obd2b into a EG4!! Help!! (Vita-Soy)
how do i remove the. immobilizer?? is it a chip??
How do i get a sponsor to sponsor me with a harness and what i need?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khmoe »</TD></TR><TR><TD CLASS="quote">I'm going to buy a b18c5 from a itr 2000 JDM OBD2b, i have research and found out that the harnes from the motor should connect to the OBD1 in the car.</TD></TR></TABLE>
This is true however if you get a JDM swap the harness will be much harder to use since it's from a RHD car. You "should" get an OBD2 USDM GSR or ITR harness.
