different IM on b18c1?
i was thinking about running an aftermarket intake manifold to make swapping a b18c1 into my ek easier. I figured this way i wouldn't have to wire up the valves from the stock IM. my questions is, if i am still using the p72 wouldn't it still look for that sensor, and if i didn't wire anything up for it, will the ecu throw a cel? thanks in advance!
Re: different IM on b18c1? (bogus_ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bogus_ek »</TD></TR><TR><TD CLASS="quote">i was thinking about running an aftermarket intake manifold to make swapping a b18c1 into my ek easier. I figured this way i wouldn't have to wire up the valves from the stock IM. my questions is, if i am still using the p72 wouldn't it still look for that sensor, and if i didn't wire anything up for it, will the ecu throw a cel? thanks in advance!</TD></TR></TABLE>
..you must be talking about the IAB's on a GSR intake manifold. You dont need to worry about this sensor, there's actually no check engine light for it, so you won't getta check light if you upgrade to a Skunk2/blox/or AEBS intake manifold (for GSR head). But your VTEC will kick on too early for the type-R style intake manifold; if you have the ecu reprogrammed or getta VTEC controller, raise VTEC to about 5300-5500rpm..
Nice_Dc2r
05-09-2003 09:04 PM
