Another B20 Swap Question
Heres my question, I plan on getting a CRX and dropping in a B20b. The only thing is I want everything converted to OBD-1, how would I do this? Is it just the injectors, dizzy, and ECU that need to be changed to an OBD-1. So all I would need is and OBD-1 LS, ecu, dizzy, and injectors on the B20 and it will run fine? I just wanted to ask and see if what I was thinking is right.
Modified by 91DroppedHatch at 2:28 PM 2/28/2005
Re: Another B20 Swap Question (91DroppedHatch)
You will also need an OBD0 to OBD1 ECU adapter harness so that the OBD1 ECU will plug in. It will require some additional wiring (convert to 4 wire O2, a few plug changes, etc.) and depending on the model (if it's not an Si or HF) then you will need to also convert to MPFI using the stock DPFI harness.
1SIKCRX
03-27-2004 04:43 PM
