Difference between h22 shafts?
Old Feb 22, 2005 | 06:29 PM
Zane's Avatar
Default Difference between h22 shafts?
I would like to know if anyone knows if there is a difference between the 92-96 intermediate shaft and the 97-01 shafts, or are they both have the same demensions?
Old Feb 23, 2005 | 10:00 AM
skunked's Avatar
Default Re: Difference between h22 shafts? (Zane)
the tranny's equiped with att's are different than the older style. I can tell you my 98 open deck block uses a diferent intermediate shaft than my 94 closed deck block. The oil filter is located in a different spot and mounted on a upward angle on the late model blocks.
Modified by skunked at 6:16 PM 2/23/2005
Old Feb 23, 2005 | 05:40 PM
Zane's Avatar
so would i be able to use my 98 intermediate shaft and 88-89 teg axles with prelude inners, or would that axle combo only work with the 92-96 int shaft? thanks fo the reply
Missa P
Feb 3, 2013 06:41 PM
CD5 Sedan
Jul 27, 2005 04:25 AM
EGhatch22
Dec 29, 2004 04:54 AM
fastwanabe
13
Nov 22, 2002 04:49 PM
