b16/R oil?...
b16/R oil?...
ok, so i have a 91' SIR B16A block and a 97' CTR head...
the block as alota miles on it and the head doesn't...but the head needs a lostmotion assimbly, so 2 of the 8 lost motion's "tick"...i was told to use thicker oil w/ cars w/ alota miles...
10W-30 is too thin, and Mobil 1 doesn't make 10W-40...so is 15W-50 ok to use on my set up?
im also useing a OEM honda oil filter.
Re: b16/R oil?... (peshte)
first off, as an experienced lube tech, i would not suggest synthetic oil on an engine with a lot of miles, therefore if conventional 10W40 works then go for that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peshte »</TD></TR><TR><TD CLASS="quote">basically...is it ok to put 15W-50 in a b16?</TD></TR></TABLE> its to thick, go gt some kendall 10w30, or 10w40 if you really think you need a thick oil
Re: b16/R oil?... (PURPLETERROR)
what would happen if i use it?...
i thik my block has arround 200K miles or more its a 91 SIR block and the doode @ autozone said it would be better fo tthe high miles...
Jesterian
14
03-24-2006 01:00 AM
