Already Searched: Need H22 help
i have a h22a4 in a 92 civic cx hatchback. my h22 throttle body is messed up and i need to change it. i have a f22 throttle body that was ported to match the h22 intake manifold. i need a vaccum diagram for the f22 throttle body. i already searced and couldn't find what i needed. soembody please help so i can get this car on the road...
Re: Already Searched: Need H22 help (jdmteg96)
you need to post more info. Are you refering to the coolant lines that run through the lower portion of the throttle body? Is map sensor mounted on the firewall or on the T-body?
This website has some diagrams....
http://www.hondaautomotivepart...UBING
Re: Already Searched: Need H22 help (skunked)
the map sensor is mounted on the firewall. its a f22a throttle body port matched to a h22a4 intake manifold. i need to know where all the vaccum and coolants lines go from the throttle body and intake manifold. its a 92 civic cx with a h22a4 swap with a f22a(94 accord) throttle body
