^*^*^*^Tranny Chattering only in 1st???^*^*^*^*
When I put the gear in first, I get this metal on metal vibrating soung, and if I tap down on the shifter, makes a noise as well, but only in first. all the other gears are smooth and make no noise. Is it clutch chatter? Is it a bearing problem? Is the gear grinding? Please need help.
Re: ^*^*^*^Tranny Chattering only in 1st???^*^*^*^* (Touch)
what clutch do you have? act 6 pucks make noise, i know that, and my act SS makes noise with my 7lb flywheel. its not tranny chatter either, its clutch chatter.the disk is bouncing off the flywheel.
maybe your shift linkage is hitting the exhaust. check that.. as for the squeaking.. its proly your pressure plate.. every Honda i have owned did that.. they get like that..
eg_b18c
Transmission & Drivetrain
17
10-31-2018 07:24 PM
carsaregood
05-11-2006 11:14 AM
Touch
09-30-2005 04:41 AM
