avid H22 race linkage
anyone used the avid H22 race linkage. i have heard good and bad things about them. just wondering if anyone has any experiances with them?
Re: avid H22 race linkage (ExplicitSpeed360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSpeed360 »</TD></TR><TR><TD CLASS="quote">stick with the cable accord/prelude and learn how to shift </TD></TR></TABLE>
i know how to shift i have had H22's befor. i was just wondering if the race linkage actually works or not. i have heard real shitty stuff about Avid. and u ran 14 flat with ur crx with a H22? thats not that impressive. i did 13.4 with kumos in a ek all stock H22 just as well.
B A N N E D
Re: (Goinfasterthanu)
the linkage is just for drag race cars it will pop out of gear every time u try to let off the clutch without yamming the gas, i talked to eric at avid racing myself cause i was looking into buying these links also.
Re: (brandond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brandond »</TD></TR><TR><TD CLASS="quote">the linkage is just for drag race cars it will pop out of gear every time u try to let off the clutch without yamming the gas, i talked to eric at avid racing myself cause i was looking into buying these links also.</TD></TR></TABLE>
i was thinking i could get away with it on a street car but i think im gonna pass thanks for the info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Goinfasterthanu »</TD></TR><TR><TD CLASS="quote">but look at his trap speed..Its good for lowwww 13's</TD></TR></TABLE>
102 mph speed trap is not a low 13 second run. we all know that a stock H22 dosent make any power up top its a low end to mid range power motor.
Re: (clayton bigsby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clayton bigsby »</TD></TR><TR><TD CLASS="quote">
102 mph speed trap is not a low 13 second run. we all know that a stock H22 dosent make any power up top its a low end to mid range power motor.</TD></TR></TABLE>
check my sig..it is a possible low 13 sec run...I have the time slip to prove it and it probably could go lower...just gotta find the shift points...
GDD Member
Re: (xv53)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xv53 »</TD></TR><TR><TD CLASS="quote">
check my sig..it is a possible low 13 sec run...I have the time slip to prove it and it probably could go lower...just gotta find the shift points...</TD></TR></TABLE>
Just gotta find the right shift points? ha, just gotta find the right altitude... you're in Hawaii dude.
Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo »</TD></TR><TR><TD CLASS="quote">
Just gotta find the right shift points? ha, just gotta find the right altitude... you're in Hawaii dude. </TD></TR></TABLE>
what i'm saying is my times can go lower i just got to find the right shift points...doing 4 only runs and running a best of 13.2@102...now theres alot a room for improvement if I did more runs...get it?
Re: (slomofo)
man in seattle i was running 13.7 in a itr with basicly just cams and i was hitting like 104mph and i ran a 13.4 with a H22 ek and i got a 105mph
