axle wont pop in...
Old Oct 6, 2005 | 10:57 AM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
Default axle wont pop in...
on the passenger side..the axle wont go in more than a hairline. i took the pin off the end of the groove and it still doesnt go.i tried jiggling it and changing the direction of the spline. i have ek with itr swap .i got the other side to work but this side is being a pain
any suggestions
Old Oct 6, 2005 | 11:13 AM
_HANS's Avatar
Default Re: axle wont pop in... (honduhh)
tttttt
Old Oct 6, 2005 | 11:17 AM
unknown0001's Avatar
use a hammer and lightly tap on it to press it in
Old Oct 6, 2005 | 04:24 PM
_HANS's Avatar
Default Re: axle wont pop in... (Mr.RHTuner)
i hit it..didnt move at all.it goes in like .5 of an inch and doesnt go any more..i move it for te splines to match up but doesnt go.im lost! help this is all i need to complete my itr swap in my ek! just the pass side is giving me problems i had it in before perfect but i had to take it out to fix the tripod!
Old Oct 6, 2005 | 05:55 PM
Dragline's Avatar
What axles are you running?
Old Oct 6, 2005 | 06:08 PM
C M S's Avatar
Default Re: axle wont pop in... (dragline)
First off you need to keep that ring on and are you using the right axle?
Old Oct 6, 2005 | 06:16 PM
_HANS's Avatar
Default Re: axle wont pop in... (BigBlock)
ya im using itr axles for my itr swap in ek,.i took them right from my itr so i know they are itr
Old Oct 6, 2005 | 06:51 PM
Dragline's Avatar
Are both axle male splines on both sides
Old Oct 6, 2005 | 06:55 PM
_HANS's Avatar
i have it in the right way. it just aint budging
Old Oct 6, 2005 | 07:04 PM
Dragline's Avatar
I'm talking about both inner's on both axles are they both male?
Old Oct 6, 2005 | 09:16 PM
_HANS's Avatar
yes
Old Oct 7, 2005 | 04:03 AM
Dragline's Avatar
If you took both axles out then you have the wrong axle in the wrong side, you need the axle with the full spline going into the trans and the one with the half spline going into the intermidiate shaft so just swap then.
jdmyo21
Feb 12, 2009 04:16 AM
creepy116
Dec 2, 2007 01:56 PM
slkleltlclh
Oct 31, 2006 12:44 PM
Quik Chris
Apr 12, 2003 06:15 PM
