ls b18 swap into 1990 civic hatch?
I crashed my integra and i want to my my b18 into my 1990 civic hatch. Is this going to be hard to do, and i am guessing now a direct swap. Will the axle's from the tegra work, or do i have to get something else. Not sure how to go about this, it is my first one on a car. ALL help appriciated!!
Yeah your axles will work if your integra was a 92. As far as mounts you will need aftermarket ones to put a b series motor in that hatch. If your hatch is not an si you will also need to do dpfi-mpfi wiring conversion. You will also need an aftermarket shift linkage or your could either cut and modify the one out of the integra.
Re: (EFvtec Yo!)
also if you have a dx you will have to change you wheel assembly's i know because that's what i had to do on my ef dx hatch good luck with your swap
Re: ls b18 swap into 1990 civic hatch? (ProjectJDMIntegra)
try this website call hybrib honda or look it up on google that will help u alot
spooncivicsi
13
04-03-2006 09:37 AM
