ECU PROBLEM (ECU GURUS HELP HELP HELP)
Old Oct 3, 2005 | 12:58 PM
Kool305's Avatar
Default ECU PROBLEM (ECU GURUS HELP HELP HELP)
Well this morning I had to get gas...
I was nearly empty...Got in the car and like always I primed the lines (fuel lines)
but this time i heard something weird...like a hollow pop sound
(empty gas tank) i thought...i proceeded to turn the car on...it fired up
after 30sec's the car just died...then there was a burnt smell...
Well I dont know if this type of **** happens when you get an EMPTY GAS TANK
IF NOT can someone tell me what caused this...???
Can someone Identify what blew? TIA...
Here are the pics...
THE DAMAGE
This is the second time this happens by the way...
Same way (on nearly empty gas tank)
(first time on my P28 and now on my P06) (the p06 was virgin)
I used this ecu to get around since my P28 was GONE!
Prior to this the only check engine light that I had was the 02 sensor
which was going to be replaced soon...
Old Oct 3, 2005 | 11:07 PM
hondaZvic's Avatar
Default Re: ECU PROBLEM (Kool305)
what pin locations are those that got burnt? (just curious)
Old Oct 5, 2005 | 07:18 AM
RACEPAK's Avatar
Default Re: ECU PROBLEM (hondaZvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic &raquo;</TD></TR><TR><TD CLASS="quote">what pin locations are those that got burnt? (just curious)</TD></TR></TABLE>
Old Oct 16, 2005 | 03:14 PM
HamiltonRex's Avatar
Default Re: ECU PROBLEM (RACEPAK)
Same thing as me.. Sent you a IM
Its the capasitor
I need to find the root cause as well
https://honda-tech.com/zerothread?id=1391178
Old Oct 16, 2005 | 07:38 PM
ultimatehonda's Avatar
There might be a short somewhere that is burning up ur ecu. I would check the main relay and the fuel pump....
Valenciabrihh
K Series
May 30, 2015 05:07 AM
Kelley99
10
Jan 21, 2009 05:48 PM
Kool305
Oct 3, 2005 06:11 PM
craiger
Jun 16, 2005 12:43 PM
