96 LS into 92 CX
96 LS into 92 CX
im gettin the 96' LS motor and trans from junkyard. the motor is obd2 and my car is obd1 i wanna stay obd1. i can just use the obd2 engine harness and pnp with it right.
another thing is that the engine is coming from an automatic and im gettin a manual trans from another yard all i need is the flywheel and clutch assembly right? and everything will just bolt right up.
O.G. triple O.G.
Re: 96 LS into 92 CX (92civichatch1)
You can use the OBD2 engine harness off the LS motor. About the flywheel/clutch...don't forget to grab the flywheel bolts because they are longer for the flywheel compared to those from the torque converter.
92civichatch1
10-28-2005 09:15 AM
1990hondaHF
06-08-2003 07:04 AM
