type R throttle body onto GSR manifold ?
Well a couple questions...
1) Is is a straight bolt on to the GSR stock manifold ?
2) With a stock head, manifold, gsr cams... would it be worth getting it ? (I might be able to get one in a parts trade)
Location: gravity rides everything...everything will fall, se GA/ne FL
1 Post
Re: type R throttle body onto GSR manifold ? (X2BOARD)
they are nice to have over a gsr. doesn't make that big of a difference. yes it's direct swap, but you should portmatch the manifold inlet as well and use type r gasket or trim the stock gsr to size.
1 Post
Re: (eg:R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg:R »</TD></TR><TR><TD CLASS="quote">how will the throttle cable go to open the t/b plate? </TD></TR></TABLE>
swap the bracket and rotor over to the ITR tb. or you can make a bracket and bolt it under the manifold where the iab stuff was, that is, if you aren't using the butterflies and have a stock gsr manifold.
1 Post
Re: (eg:R)
swap the bracket and rotor over to the ITR tb. or you can make a bracket and bolt it under the manifold where the iab stuff was, that is, if you aren't using the butterflies and have a stock gsr manifold. i ran a type r throttle body with stock gsr manifold and ran it under the runners with stock civic cable and custom bracket.
vlc92189
02-05-2007 06:49 PM
THEUSED
12-29-2005 08:30 PM
